Ericsson ENM IP Address
Hello All,
How do we get IP address of ENM. I would like to troubleshoot OAM Issue of a node. As a first step I wanted to do a Ping test by keeping source as ENMIP and destination as OAM IP of node.
Hi, @Sooraj, by default you are ping from VM’s address you’re connected to. There is no need to specify source ip address.
Yes, I can see it’s not pinging, but our team will require source IP which is ENM to investigate the issue further.
@Sooraj try eth1 from output
ifconfig
Thank you. Also when I did traceroute to destination OAM IP, I could see gateway of VM.
