I am getting failure due to L.E-RAB.AbnormRel.Radio.ULSyncFail in Drop Call Rate.
Vendor is Huawei.
Please share the ways to improve the DCR.
Thanks
Vendor is Huawei.
Thanks
In Order to decrease CDR & L.E-RAB.AbnormRel.Radio.ULSyncFail and Enhances the uplink timing reliability and reduces the out-of-synchronization probabilities.
Command:
MOD TATIMER:LocalCellId=X, TimeAlignmentTimer=INFINITY, TimingAdvCmdOptSwitch=ON.
Hi
Yes agreed with Cheikh789,
Add one more thing,
GLOBALPROCSWITCH:UELINKABNORMALDETECTSWITCH=OFF; (Turn on to off)
Hi,
This parameter is already aligned with the mentioned.
Please suggest any other parameters.
You can adjust the parameter using MML command “MOD RLCPDCPPARAGROUP”
enodeBPollRetransmitTimer=Tpollretrans_m200;
UEPollRetransmitTimer=Tpollretrans_m200;
Recommended to tune same value for both, in order to have same gain for uplink and downlink sides.
check if there is interference or whether operations or modifications are performed
