Cell range C2.
Ok, means you are using short preamble, not long preamble.
What is SCS for C2?
Yes, short RACH used for NR A2, B2, C2.
it’s 30 kHz.
What is your average inter site distance for NR carrier?
I am asking because do you really need cell radius of 4.6 km?
Outer site with TA 900 meter.
Don’t have planning input, but yes I think site capturing high TA samples.
I would suggest to try changing from 0 to 14 or 15 , in order to improve RACH SR.
Try 1st with 15.
Hi, Could you please suggest what could be the reason in the first 5G site in the region with RSI of 16 between cells and cellrange as 5km ? I don’t have any other 5G sites atleast for 10km. I am seeing lot of DTX and CRC failures in Msg3.
