Expert’s,
Please help to clarify throughput calculation with 20 MHz B.W, 64QAM - TM2 (Tx Diversity) TM3 (Open Loop MIMO) TM4( Close Loop MIMO)…
How throughput will be calculated and with which TM mode we will receive more throughput…
Please share your valuable thought with calculation …
Thanks,
In one go tm4 having more throughput for calculation part it’s long equation.
Yes @ankgitm, absolutely correct .but need practical expression for the data flow…
Pls share flow of data with all above MIMO mode if you have …
Thanks
Can you share references for it? Thanks.
@Pankaj
Basically close MIMO TM4 .work on feedback mechanism of PMI,RI,CQI…
And per channel condition if it’s good more weight is assigned along with more resources…
So it’s continuous improve RB Assignment by the feedback that’s why I believe it provide more throughout.another factor support of MIMO layer at UE side also taken.
