In modern (RAN), addressing capacity or coverage imbalances between sectors is a core optimization task. While hardware resources (like baseband units) are increasingly pooled, the “sharing” of radio resources between sectors usually involves steering the (UE) to the least congested cell.
The most effective methods to support a struggling sector using neighboring resources:
1. Load Balancing (Mobility-Based)
This is the most common approach. Instead of the hardware “reaching over,” the network encourages UEs at the sector edges to hand over to a neighboring cell that has more available Resource Blocks (RBs).
* Intra-Frequency Load Balancing: The network adjusts the Cell Individual Offset (CIO) for the congested sector. By making the neighbor look “better” than it actually is, the UE triggers an A3 measurement event earlier, offloading traffic to the neighbor.
* Inter-Frequency/RAT Load Balancing: If the neighbor has different frequency layers (e.g., shifting 5G users to a 4G layer or a different 5G band), the network uses Blind Redirection or Measurement-based Release with Redirection to clear capacity.
2. Coverage Shaping & Antenna Optimization
If the issue is coverage-related, you can physically or logically “push” a neighboring sector’s footprint into the problem area.
* Remote Electrical Tilt (RET): Reducing the downtilt on a neighboring sector can extend its coverage into the weak zone of the primary sector.
* Azimuth Adjustments: Rotating the neighbor’s orientation slightly to cover a specific “hotspot” that is currently choking the primary sector.
* Massive MIMO Beamforming: In 5G NR, you can implement Vertical and Horizontal Beamforming. You can configure specific “narrow beams” to point toward the high-demand area, effectively borrowing the neighbor’s spatial resources without affecting its overall footprint.
3. Baseband Resource Pooling (Cloud-RAN)
In a traditional Distributed RAN (D-RAN), resources are locked to the site. However, in C-RAN (Centralized/Cloud RAN) or Open RAN architectures, the baseband processing is decoupled from the Radio Units (RU).
* Resource Pooling: A centralized Baseband Unit (BBU) pool can dynamically allocate processing power to the sector experiencing a spike in traffic.
* Coordinated Multipoint (CoMP): This is the “gold standard” for resource sharing.
* Joint Transmission (JT): Multiple sectors transmit the same data to a single UE simultaneously. This improves signal strength (SINR) significantly for edge users.
* Dynamic Point Selection (DPS): The network instantly switches the data transmission point to the neighbor if it offers a better link, reducing the load on the primary sector.
4. Advanced Software Features
Vendors (Huawei, Ericsson, Nokia) offer proprietary features for this:
* Carrier Aggregation (CA): If the neighboring sector has a different carrier, a UE can be anchored in the primary sector but pull data through the neighbor’s carrier as a Secondary Cell (SCell).
* Super Inter-Cell Spectrum Sharing: Allows a sector to “borrow” unused spectrum chunks from a neighbor on a millisecond timescale, though this requires high-speed fronthaul and tight synchronization.
To choose the best approach, one should first determine if the “problem” is Hardware Congestion (CPU/Baseband), Air Interface Congestion (RB Utilization), or RF Environment (Interference/Weak Signal).
Reference: Huawei Mobility Load Balancing (5G RAN6.1)
Reference: Radisys: Coordinated Multipoint Tx and Rx
Reference: Analysis of Carrier Aggregation for Spectral Efficiency (MDPI)
Reference: Ericsson: 5G Advanced and AI-powered RAN
