Brazil's FWA Internet Revolution: Mapping Cellular Towers for Rural Coverage & Enterprise Fiber Backup
In Brazil, where fiber optic reach is limited in rural areas and enterprises demand uninterrupted connectivity, Fixed Wireless Access (FWA) emerges as a critical solution. I’ve developed Mapa das Torres de Celular do Brasil (mapadastorres.com) - a web platform that optimizes FWA deployments by predicting signal coverage with carrier-grade accuracy, using real tower data and propagation models.
Key Use Cases:
:satellite: Rural Connectivity:
  • Identify high-signal towers for FWA installations in areas without fiber
  • Analyze terrain obstacles & Fresnel zones to avoid dead zones before deploying antennas
:office: Enterprise Redundancy:
  • Plan cellular backup links for failover when fiber fails
  • Compare multi-operator towers (Vivo, Claro, TIM and others) to ensure uptime
Technical Edge:
:mag: Search for Towers: Find towers within a 30km radius of your location on an interactive map
:wrench: Tower Data: EIRP, azimuth, tilt, power and frequencies (2G/3G/4G/5G) from Anatel’s database
:signal_strength: Propagation Modeling: Signal propagation algorithms + terrain elevation (SRTM) for realistic coverage simulation
:dart: Receiver Antenna Configuration: Customize calculations by setting your antenna’s gain (dBi) and height for precise results
Operational Insights:
  • “Will this 4G tower work for my farm’s internet?”
  • “Which operator’s 5G tower is best for my office’s backup link?”
Why It’s Unique:
  • Bridging the Digital Divide: Already helping rural ISPs and enterprises reduce deployment risks
  • Proven Adoption: Ranked on Google’s first page, with hundreds of weekly users validating coverage predictions
Let’s discuss FWA in Brazil!
:point_right: Try the tool: https://www.mapadastorres.com
:point_right: Feedback? Comment below
