Boda - ZTE CM Data (Dump)
These are steps to get ZTE CM (Configuration Management) Data from to use with Boda.
ZTE BULKCM Format (2G)
Exporting BULKCM 2G via GUI
  1. Launch “ZTE NetNumen OSS”.
  2. In the left topology tree of NetNumen U31 main interface, right-click the shortcut menu Corresponding to the created GSM NE agent, select Start.
  3. Right-click the started GSM NE and select Start.
  4. After the NE is started, in the left topology tree of NetNumen U31 main interface, right-click shortcut menu corresponding to created GSM NE agent, select NE Agent Management > Configuration Management.
  5. The Configuration Management tab is displayed.
  6. In the configure resource tree window, right-click OMC > GERAN subnet user ID > BSC Management Element ID > Config Set ID > BSC Function ID > Export Configuration Data > Export Network Plan Data.
  7. Click Export Network Plan Data, and the Choose MOC to be Exported dialog box appears.
  8. Select the parameter list to be exported, and click Next, as shown in Figure.
  9. In the Choose Attributes of Each MOC to be Exported (RDN Excluded) dialog box, select attribute of the parameter list to be exported, and click OK. Here, suppose the MOC selected is IBSCFUNCTION_TABLE.
  10. Select the file type to be exported and click OK. Here, suppose the data is exported to be an Excel file.
  11. Set the saving path and file name for the exported data and click Save.
Exporting BULKCM 2G via CLI
TBD
ZTE BULKCM Format (3G)
Exporting BULKCM 3G via GUI
  2. In the Topology Management window, right-click the NE agent, and select NE Management > Configuration Management. The Configuration Management window is displayed.
  3. In the Configuration Resource Tree, click the RNC Managed Element node, and select RNC Managed Element > Configuration Data Export from the menu. The Data Export dialog box is displayed.
  4. Select the RNC from the RNC Identity drop-down list.
  5. Select a configuration set from the Config Set Identity drop-down list.
  6. Select XLS from the Export Format Type drop-down list.
  7. Click the Radio Management Object tab (Data Export Dialog Box - Radio Management Object Tab).
  8. Select the check boxes corresponding to the radio management objects to be exported.
  9. Click Export Data. A dialog box is displayed.
  10. Select the directory where the live radio parameters are to be saved, and then click Save. A message box is displayed, prompting that the information of the selected objects has been saved in a compressed Excel file (ZIP file).
Exporting BULKCM 3G via CLI
TBD
ZTE BULKCM Format (4G)
Exporting BULKCM 4G via GUI
TBD
Exporting BULKCM 4G via CLI
TBD
Resources
hello,
if you need i can share new way how to export data for everything with simple click
respects.
@Redouane please go a head and share.
Dear
ok waiting for this way
