ZTE 3G XML OSS Parameters Dump Parser
#1
Hello members.
Here you will find the Hunter’s Boda parser for ZTE 3G XML.
This specific post is for ZTE 3G XML issues only. If you have questions regarding other Vendor/RAT, please either find the appropriate topic or create a new one - if not already created.
The following sections contain the steps to obtain a ZTE 3G XML dump and parse it.
Step by step procedure to download and configure Hunter Boda ZTE 3G XML Parser
  1. Click the link below and download boda parser to an appropriate folder on your computer.
    Tip: follow the recommended Hunter folder structure so that it will be easier to organize future parser versions, and also other parsers for other RATs.
    Download Link: boda-bulkcmparser.zip (10.7 KB)
  2. The Hunter Structure starts with a “Hunter” base folder. Then, a subfolder for “Boda”. In the Boda folder, create a folder for this parser (“ZTE_3G”). And finally, the module folders: “Scripts”, “Output” and “Data”.
  3. For now, we will follow the Hunter folder structure and download the BODA Parser “boda-bulkcmparser.jar” to “C:\Hunter\Boda\ZTE_3G\Scripts”
Step by step procedure to download ZTE 3G XML Configuration Parameters from OSS
Let’s obtain the raw CM dump file.
  1. Launch “ZTE NetNumen OSS”.
  2. In the Topology Management window, right-click the NE agent, and select NE Management > Configuration Management. The Configuration Management window is displayed.
  3. In the Configuration Resource Tree, click the RNC Managed Element node, and select RNC Managed Element > Configuration Data Export from the menu. The Data Export dialog box is displayed.
  4. Select the RNC from the RNC Identity drop-down list.
  5. Select a configuration set from the Config Set Identity drop-down list.
  6. Select XML from the Export Format Type drop-down list.
  7. Click the Radio Management Object tab (Data Export Dialog Box - Radio Management Object Tab).
  8. Select the check boxes corresponding to the radio management objects to be exported.
  9. Click Export Data. A dialog box is displayed.
  10. Select the directory where the live radio parameters are to be saved, and then click Save. A message box is displayed informing you that the information of the selected objects has been saved in a compressed file (ZIP file).
Following the Hunter folder structure, download the file to “C:\Hunter\Boda\ZTE_3G\Data”. This folder will hold this specific dump. Of course you can download to any other folder you want - just make sure it will be easy to find later. :slight_smile:
Step by step procedure to parse (process/extract) ZTE 3G Configuration Parameters
With the raw dump file downloaded, let’s extract the parameters!
  1. First, check if the downloaded files are compressed (ZIP, RAR, 7-z, GZ, etc…). If so, uncompress them using any compression/uncompression utility such as Winzip, Winrar or 7-zip.
  2. Next we run the parameter extraction command. We advise you to create an auxiliary text file, to store/modify the command. Under the Scripts folder, create a file called “zte_3g_xml_usage.txt” to store the command.
    Adjust the command based on the syntax below:
    “java -jar boda-bulkcmparser.jar inputFile outputDirectory”
  3. Run the command and wait for it to finish.
    IMPORTANT: Please make sure you run the command on ONE LINE ONLY (not on separate lines).
  4. Done! All your parameters will be extracted into csv files. These can be opened using any text editor, Microsoft Excel or Access .
Example
"java -jar C:\HUNTER\Boda\ZTE_3G\Scripts\boda-bulkcmparser.jar C:\HUNTER\Boda\ZTE_3G\Data\example_data_subfolder\example_cm_file.xml C:\HUNTER\Boda\ZTE_3G\Output\example_output_subfolder\"
Where:
“C:\HUNTER\Boda\ZTE_3G\Data\example_data_subfolder” is the folder where you have your dump file;
“example_cm_file.xml” is your dump file;
“C:\HUNTER\Boda\ZTE_3G\Output\example_output_subfolder” is the folder where all CSV files will be created.
For a more detailed example, please check this topic: General instructions for using the CM parsers to process any network dump
That’s it.
Hope you all like and participate.
Help us by inviting your friends to the community, feedback/suggestions, and of course asking us whatever issue you may find.
Let’s build a totally new Telecom/IT global community.
BR,
Emmanuel
#4
Hi all,
A new version of the parser has been released. Everyone is strongly advised to download and use the new parser. Also, note that the old parser will/may not work after 1st August :). This we did so that members can get access to the new features and bug fixes.
Otherwise, enjoy and let us know if you run into any issues.
Emmanuel
