Why does session disconnect when signalling msg is fast dormancy?
#1
Hi can anyone tell me about why session is disconnect when signalling msg is fast dormancy?
Internet session disconnects frequently and I saw the PCHR MSG is fast dormancy.
#2
Is strange but check if all parameters are correct… Have you created second FACH?
#3
Not sure. Need to check
#4
Or second S-CCPCH?
#5
Ok I will check which one will help?
#6
And check VS.DCCC.FastDormUe.DF2P.Att and VS.DCCC.FastDormUe.DF2P.Succ if the values of these two counters are not 0, the EFD function has taken effect…
LST USCCPCH check if you have SCCPCH ID 8 and 9 create
#7
What’s is the release?
#8
Release is RAN15
#9
Ok let me check
#10
What is your suggestion?
#11
Check out the documents at the links below for the description of the EFD… Check if everything is ok
