What parameters should be checked if some cells in RNC have zero IRAT CS out attemps?
#1
What are the parameters to be checked if for few cells in RNC having zero IRAT CS out attempts
Huawei RNC…
#2
Have you checked 3g to 2g relations?
#3
GSM relation exists
#4
Check iRat switch is it on.
#5
RNC level switch is ON, how to check for individual cell
#6
Verify external table as well…
#7
Verified External gSm bcch,bsic,lac & Rac found ok…
#8
You should check the event triggering thresholds for those cells. Wheather is it set to high value … Map it with other cells which are normal.
In zte the parameter is URatMeasProfile.
#9
I need know it in Ericsson and Huawei
#10
Sorry no idea.
#11
Cs out was working before and suddenly stopped or it never work ?
#12
Out of 13 cells, 12 cells never has IRAT CS out attempts and 1 cell having this now only
