What needs to be checked in Huawei to combat ERab success degratdation
#1
Erab success degradation reason pls… And what need to be checked in Huawei system
#2
Check licence
#3
Any other clue
#4
RRC connected user…There is a counter
#5
Which counter in failure incremented? Any operation performed?
#6
Rab failest no radiores.
Check the correlation with erab
If they are match check RRC connected user licence
#7
OK thx… Will check
#8
Please let us know if you find anything
#9
Sure. Will do
#10
this cause is for Erab failure… Any clue on this on Nokia system? What steps need to be taken?
#11
Resource congestion? Should be PDCCH & SCH congestions
#12
Can be a license issue
RRC USER and licensed user
#13
It is license for sure.
if Huawei use the command: CHK DATA2LIC to check it
#14
Thanks will do that
#15
ERAB setup failure due to resource might be due to faulty board ,exporting board logs for that site and analysed through compatible tool will show you if board shows any relative message.
You can also check this via board related counters
#16
Any counter for Nokia system pls
