Nokia BSC/RNC/LTE - Parser to XML (Script Generation)
#1
Hi
I found the Nokia OSS Dump parser here which is really useful and I must say thanks to the creator for helping us out in parsing the dumps.
I am curious if there is any script generator that converts the parsed excel / csv files to the XML file for bulk network changes?
If so can you please help?
Thanks
