Is there any Nokia similar parameter to Huawei CQI Feedback Cycle K (CQIFbCk and CQIFbCkforSHO)?
"Parameter determines if Wideband CQI or UE_selected subband CQI report mode for periodic CQI reporting on PUCCH or PUSCH should be used.
If periodicCqiFeedbackType is set to UE_selected subband CQI this means that UEs supporting subband CQI (prooved via check of FGI) use it and UEs which do not support subband CQI will use wideband CQI.
Note for the case where periodic subband CQI reporting is enabled together with DRX functionality (actDrx):
It may not be possible to synchronize DRX start offset such that the wideband CQI report is received during the DRX OnDuration (due to periodicities) and that may cause small performance degradation in DL whenever fresh wideband channel quality information cannot be get in time. It is up to an operator whether to prevent activation of periodic subband CQI reporting and DRX in parallel because of this restriction."
