Ideally what should be maxdlpower/maximum transmission power value for a 60w cell. Vendor E//
it depends on the attenuation and the carriers, but it could be 460…depends on the configuration of the rru…RRU RUS12 are 120w, you must validate the license
460 is maxdl or maxtransmission power
Maxdlpower=478-dlattenuation
60watt==>47.8 dbm
But u need to check power license and RRU supported power
