How can I resolve Vs.RAB failEstabPS.RNL and what causes it?
#1
Can any one tell me how can I resolve this fail: Vs.RAB failEstabPS.RNL? What’s the main cause? My cssr hsdp is down
#2
Is the site transmission full IP? Check if there IP Path fault alarms from RNC side
#3
Ok, I will do it
#4
Hi WhatsappUser2! I have the same case with Victorlud. I also have a IP Path fault alarm when checked at NodeB from U2000. May you share with us the significance of this alarm on the high Vs.RAB failEstabPS.RNL?
Thank you.
