Ericsson 3G XML OSS Parameters Dump Parser
#23
Hello expert
XML parser is good and it’s working fine.
But since week…it is not working.
Means no file.generate in output data.refer my attachment in CMD…it is showing parsing completed but no file.generated.in output folder.
Uploading…
#24
Hello Emmanuel
Please help on below query.
Bhavesh_Rathod
6h
Hello expert
Uploading…
#25
Hi @Bhavesh_Rathod,
You did not attach a screenshot. Do you mind trying to upload it again?
Emmanuel
#26
A new version of the parser has been released. It fixes some issues around column misalignment and missing MOs. Everyone is strongly advised to download and use the new parser. Also, note that the old parser will/may not work after 1st August :). This we did so that members can get access to the new features and bug fixes.
@Bhavesh_Rathod, let us know if the new parser fixes your issues.
@nopalez, let us know if the missing parameter issue is now fixed for you.
Otherwise, enjoy and let us know if you run into any issues.
Emmanuel
#27
Hello
From Where to download new updated Ericsson 3G parser…
#28
@Bhavesh_Rathod, the download link is in the initial post.
#29
Hi Emmanuel
Is this below link
#30
@Bhavesh_Rathod, yes it is.
#31
Hi Emmanuel, I am now getting all of the “missing” parameters ! Thanks for the support!
#32
Hi,
I’m trying to run the parser and getting the following error:
D:\temp\cm>java -jar boda-bulkcmparser.jar d:\temp\cm\CM_test.xml d:\temp\cm\cm_
test
Extracting parameters from CM_test.xml…Exception in thread “main” java.lang.No
SuchMethodError: java.util.Map.replace(Ljava/lang/Object;Ljava/lang/Object;)Ljav
a/lang/Object;
at com.bodastage.boda_bulkcmparser.BodaBulkCMParser.collectVendorMOColum
ns(BodaBulkCMParser.java:1172)
at com.bodastage.boda_bulkcmparser.BodaBulkCMParser.endELementEvent(Boda
BulkCMParser.java:748)
at com.bodastage.boda_bulkcmparser.BodaBulkCMParser.parseFile(BodaBulkCM
Parser.java:322)
at com.bodastage.boda_bulkcmparser.BodaBulkCMParser.processFileOrDirecto
ry(BodaBulkCMParser.java:442)
at com.bodastage.boda_bulkcmparser.BodaBulkCMParser.parse(BodaBulkCMPars
er.java:387)
at com.bodastage.boda_bulkcmparser.BodaBulkCMParser.main(BodaBulkCMParse
r.java:369)
Can you advise ?
#33
@fabluis, update your Java runtime version. Use this link https://java.com/en/download/
We’ll look into supporting earlier versions in the future. After downloading, installing and re-running, please confirm that all is well.
Emmanuel
#35
Hello dears when I am trying to use this parser it is saying that usage time is expired and I should communicate to administrator. Could you please support me to solve it. Thank you very much in advance.
#36
Hi @Giga_Tsiskaridze, download the new version. Use the link in the original post at the post of the page.
BR,
Emmanuel
#37
Hello Emmanuel,
I am so sorry but I don’t understand what do you mean.
I have downloaded new file from the top of this post and still I got below listed problem.
“Parser has expired. Please request new version from www.telecomhall.net
#38
I have checked and the link and file are both fine. You are using an old version of the parser.
#39
Dear Emmanuel, Could you please give me the exact Download link. Thank you in Advance
#40
http://telecomhallforum.s3.amazonaws.com/original/1X/638f635a89fbf67fe8432124215bb48cfece4b87.zip
#41
Hi ,
if I have three 3 file *.xml. I follow your guideline. Will the result be combined data from 3 file to on sheet or not ?
#42
@Quang_Nguyen_Danh, data for each managed object will be in a single file/sheet for all files.
#43
Thank you for your support! Emmanuel
