Ericsson 2G CNAIv2 OSS Parameters Dump Parser
#22
Dear Emmanuel,
Now it works.
Thank you very much.
#23
Hi Emmanuel, i’m having same issue as Daniel_V. parser finishing well but no CSV are created. the dump i have is one exported from OSS using cna_export OSS app. what can i do?
#24
Hello @Guillermo_Gustavo_Go,
Are you sure the dump is in the correct format?
It only work for command cnai_v2, not for command cna_export
CNAI version 2 command: > cnai export valid -i > YourFileName.txt
#25
these are my options
usage:
cna_export [AREA = user:area_name,]NW = network,
MSC = obj_file | all,MSC_REF = param_file | none | all,
[OUTERCELL = obj_file | all,OUTERCELL_REF = param_file | none | all,]
[BSC = obj_file | all,BSC_REF = param_file | none | all,
[PP = obj_file | all,PP_REF = param_file | none | all,]
[SITE = obj_file | all,SITE_REF = param_file | none | all,
[TG = obj_file | all,TG_REF = param_file | none | all,]]
[CELL = obj_file | all,CELL_REF = param_file | none | all,]]
OUTPUT = transfer_file_name[,MNCZEROEXPAND = yes | no ]
or
FCELL = obj_file | all,FCELL_REF = param_file | none | all,
or
RNC = obj_file | all,RNC_REF = param_file | none | all,
[UCELL = obj_file | all,UCELL_REF = param_file | none | all,]
Hint: With long command lines or for convenience, use either a script or source file.
don’t see CNAI version 2 command: > cnai export valid -i option
#26
Hi.
Even not “seing” the option, it is there.
In the command line, type:
And hit Enter
Check for the file created.
Please tell us if you have some error
#27
Perfect! sorry i didn’t know about the existence of this command and suspect spaces will not work.
many thanks for your quick response.
BR
#28
I am looking for a company that can recycle GSM 2G antennas for mobile telephony operators. We have a large inventory of 2G GSM antennas for recycling
#29
Hello Guys,
Yesterday I runned the parser successfully, but today I am getting the following error message:
“Parser has expired. Please request new version from www.telecomhall.net
I have already tried the most recent available version, with no success.
Is it possible to some of the developers of the tool remove this restriction, please?
Thanks,
Cesar
#30
@Cesar_Sanfelice,
The parser has been updated. Use the download link in the original post.
Emmanuel
#31
Thanks @Emmanuel, but with this new version I am getting the following error message, running the same command line:
Exception in thread “main” java.lang.NoClassDefFoundError: java/nio/file/Paths
at com.bodastage.boda_ericssoncnaiparser.BodaCNAIParser.processFileOrDirectory(BodaCNAIParser.java:211)
at com.bodastage.boda_ericssoncnaiparser.BodaCNAIParser.main(BodaCNAIParser.java:185)
Caused by: java.lang.ClassNotFoundException: java.nio.file.Paths
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
… 2 more
Could you help me?
Thanks,
Cesar
#32
@Cesar_Sanfelice,
Update your Java installation. https://java.com/en/download/
#33
Thanks Emmanuel,
I am running directly in the OSS Server without admin access, but saving an updated java version in my user´s home folder, it worked!
Thanks a lot,
Cesar
#34
Hi Emmanuel, Can you please provide eaw printout parsar for 2G.
#36
Hi @mithun, I will let you know when it has been uploaded.
#37
Hi Emmanuel,
can you share to us new version of the parser? (message : Parser has expired. Please request new version from www.telecomhall.net )
#38
@DSolo, the parser has been updated. The expiration has also be removed.
#39
Thank you very much. You save my job… :beers:
#40
Olá Cesar, como vai você?
Qual versão você usou Java para fazer isso a partir do OSS ???
Obrigado
#41
@Mauricio_Santiago
Checkout that article at the link below. It shows how you can install an up-to-date version of JDK/JRE in your OSS account.
http://www.oracle.com/technetwork/java/javase/install-linux-64-self-extracting-142068.html
#42
Hi Emmanuel, the java version on the server is this:
java version "1.6.0_115"
Java™ SE Runtime Environment (build 1.6.0_115-b12)
Java HotSpot™ Server VM (build 20.115-b12, mixed mode)
With what minimum version does the script work?
Thank you.
