Does any one know if in eRan 6.0 the LBBP works in pool?
Which hardware version of LBBP u r using? for example pool works on cell and user level on LBBPc boards since eRAN2.
We are using LBBPd and eRAN 6.0 but here Huawei said that LBBP does not have pool.
If I connect 3 RRU in the same LBBP this will have all processing and the other one no.
Remember: Here i have two LBBP and all RRU are conected in only one of them. In other LBBP the CPU processing is zero because HW said that LBBP does not have pool. Is it true?
LBBPd…I received info from local guys (Huawei) that LBBP does not work in pool for eRan 6.0
Yes it works. But when you say in pool is like configuration for 3 sector something different?
No…when I said pool I said about the CPU load. Always the LBBP where are the 3 sectors have more CPU load that the other LBBP.
sorry…we are using eran 6.0
