Hi guys Hi guys can we have same lac from 2g and 3g?
paging will be done on both 2g/3g then…not recommended
OK… Thanks
There are some advantages in doing this. Already saw some operators doing this to avoid all the signalling relates to location update.
Air interface wilk be limited n congestion may arise
It depends on. For example if transition between 2G and 3G ocurrs too much, by doing this it can avoid paging missing…
We are using it and we dont have any issue in our network. Try to make good dimensions on your lac
