Brazil Mobile Operators - Map with Location of all Stations (Sites ANATEL)
Hello,
This is the download page for the Google Earth Map with geo information of all Sites (Stations) for All Brazilian Mobile Operators.
Update: You can find source code here Hunter 020 - GE Operators
Download: please check telecomHall Brasil (page for telecomHall Community in Brazil; map is under “Relatórios”)
Dear Mr Pedrini,
Is there a datasource with all these base stations including their MNC, LAC and CID?
Thanks a lot in advance.
These are Design Information… And it’s not shared (not public info)
Please, could you help me with the availability of the most up-to-date anatal brazil tower base? For example December / 17
thanks,
Please, can anyone help in this update?
SO, You must go on the website of antatel.gov.br and take download the database the whole site in Brazil .
I hope have help you!
Sorry , anatel.gov.br :smile:
Here you go:
Does anyone have the KMZ ERB BRAZIL 2019?
The best way to get Brazil cell towers location is to visit Brazil’s Regulator page:
https://sistemas.anatel.gov.br/se/public/view/b/licenciamento.php
You can download data (Excel) and use Hunter KML Plotter to plot it to KMZ (Google Earth)
any map of other country? thx,
Caros , não tem o ID do Site Claro/oi/tim/ somente a licença anatel, alguma forma de descobrir o ID do site na localidade?
That Anatel site is impossible to handle.
You simply cannot filter via state/municipality.
I’ve updated the generated map:
Download:
Hunter_Network_Benchmarking_ANATEL_MAP BRAZIL 2022_W05 (23-Jan a 29-Jan).zip (7.0 MB)
any update?
Here: (In Portuguese)
