Boda - Use PostgreSQL DB without installing it
Suppose your company has strict security policies that don’t allow you to install software. In this case, to use Boda + Database, you can follow steps below (on Windows OS) to use PostgreSQL without installing it.
  1. Create a folder for your Postgres download (POSTGRES_FOLDER).
  2. Launch cmd terminal and go to POSTGRES_FOLDER
    cd POSTGRES_FOLDER
  3. Download PostgreSQL using the download script bundled with Boda-Lite
    C:\Users\<USERNAME>\AppData\Local\Programs\Boda-Lite\resources\db\scripts\download_postgres.bat
    Where <USERNAME> is your user name on Windows.
The image below shows the output from running this script
  1. Initialize PostgreSQL
    PostreSQL\pgsql\bin\initdb.exe -D ..\data --username=postgres --password=boda
  2. Run PostgreSQL database
    PostreSQL\pgsql\bin\pg_ctl.exe start -D ../data
Resources
