Boda Lite 0.4.5
Hi all,
Below are the links to download Boda-Lite 0.4.5.
Minimal Requirements
To run Boda Lite, you need to have the following minimum requirements:
  1. 4GB RAM Memory (Althougth it’s recommended 16GB - or at least 8 GB)
  2. 5GB Hard Disk space. (More space will be required depending on your network size)
  3. 64-bit OS
  4. JAVA is installed
Log in Credentials
email: expert@telecomhall.net
password: password
NOTE:
  • If you are currently on 0.4.2, there is no need to re-run the database setup.
  • For versions 0.4.1 and earlier, you will need to re-run the database setup after installation so that the changes to the database can take effect: Troubleshooting Boda Lite
Windows:
Linux:
Mac:
Recent changelog:
v0.4.5
  • Fix bug in KML Generator
  • Add baseline configuration upload with excel file
v0.4.4
  • Checks if Java is installed
  • Fixes bug in KML Generator causes endless run of small files
v0.4.3
  • Adds parsing of Huawei MOTree XML CM dumps
  • Fixes bug in importing TEMS file with LTE data, in GIS module
  • Fixes crashing of app when edit option is clicked on inbuilt reports
v0.4.2
  • Fixes bug in Ericsson BulkCM parser; updates it to 2.2.5
v0.4.1
  • Adds KML Generator Utility. This takes a csv or excel file as input and allows you to easily generate KML cell files.
  • Fixes bug with database setup
  • Updates Nokia RAML relation queries
Previous releases: please contact developers.
Resources
Great Work @Emmanuel
You too @Murali
Thank you!
It is a fabulous tool, great job, you made my life easier.
Good Job, Lets keep it ON.
a question please.
is there any document showing how use the tool functionalities, for example I want to use the option of baseline audit, but I don’t know how to proceed.
BR
http://www.telecomhall.net/t/boda-quick-reference-guide/6305/2
Very useful. Thanks
Thanks, Three thousand…
