Boda Lite 0.2.3
Download Links for Boda Lite v0.2.3.
Note: not sure what version to install? Check latest versions here telecomHall Experts Handbook
Windows:
Linux
Mac OSX:
Log in credentials
email: expert@telecomhall.net
password: password
Change Log:
  • Added option to select the number of rows to display in tabular reports
  • Added CM tables missing in 0.2.2
  • Added count of csv files remaining to be processed as loading progresses(in the log file)
  • Fixed bug blocking downloads because of un-sanitized report names
  • Added parser output to log file for better troubleshooting
  • Added editing of composite reports
  • Added script to manually download and run PostgreSQL db without installing
  • Fixed handling of double quotes in csv files that was causing some files not to be loaded
  • Added network entity reports
  • Added separate release build for windows installers
  • Added generation of snap and rpm packages to linux release build
Resources
