Anyone implemented TD-LTE subframe other than 2?
#1
#2
Yes. We did that. Whats ur need??
#3
theoritically shifting from 5ms (subframe config 2) to 10ms (subframe config 4 or 5) will make less opportunity for ul feedback such as HARQ, BSR etc. and uplink resources will limit
currently we have 10:1 DL:UL traffic ratio and we are using config 2 which is 3:1 (DL:UL). So I was thinking why not move to config. 4 or 5
i was looking for any report or case study when moving from config 2 to 4 or 5
#4
what will be the impact on KPIs and unforseen issue?
#5
Which provider?
#6
perhaps some UEs don’t support config 5. The provider/vendor is Huawei.
Note that Huawei doesn’t support config 4
#7
Which release note??
#8
and for massive MIMO only config 2 is supported
eRAN8.1
#9
Ok bro
So u have to be sure rhat software is supporting conf 4 and 5
Be sure also about ue capability
#10
For massive MIMO i remenber that u need to upgrade to ran12.10
#11
yes it is in our roadmap
#12
Massive MIMO u have to use 65t/64r
#13
yes I know
#14
Also in ur road map?? Good
Soft split is ur road map also??
#15
do u have any practical experience?
#16
Yes. 5 years LTE leader FDD and TDD
#17
so did u face any issue when changing config
#18
Now i’m managing 8T/8R solution…with eran12.1.
Yes
#19
I am talking about experience regarding my query
#20
Yes. I faced problems. The network support only one conf
